Batch to Change Attributes
Does anyone have a journal that you can run as a batch on a folder of files that you can put several different attribute titles into and have it either change the titles and/or have it copy the value from that title and add a new attribute title with the pasted value?
In the end, I am looking for something that will change the attribute titles to something else but keep the value for several attributes in every file.
Also, if at all possible, can you copy a value from a named object attribute and paste it into a part attribute?
I am currently running NX 7.5.
Thank you for any help that anyone can provide.
