Question about using thermal camera for temperature measurements in a laser processing environment
I am working on laser process where I would like to measure online temperature measurements using a IR thermal camera. I am worried about the safety of the device from any scattered laser radiation. The laser type is also IR (0.9 micron to 1 micron). Would like to know about the precautionary measures I need to take to safeguard the device.
Thanks a lot
Thanks a lot
RE: Question about using thermal camera for temperature measurements in a laser processing environment
your camera will be fine
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
