NX10 Touch Screen
NX10 Touch Screen
RE: NX10 Touch Screen
Hi Didier,
Can you check if the Language-Setting of Windows changes when this Pop-Up appears?
I have NX9 on a Surface Pro 3 and hoping to test NX10 very soon, still waiting for the License...
Best regards
Hi Pascal,
No it doesn't change but i Am not sure about the way to check it. Send me the process please
Didier Psaltopoulos
http://www.psi-cad.com
I found the answer, it was so simple smile
It's necessary to go at least one time to the full keyboard by clicking "ABCD" then set CAPS LOCK
Didier Psaltopoulos
Hi PascalDW
Which Surface do you have? How looks graphics on it. I thinking to buy one (surface 3 pro, I7 and 256mb), i will use it mostly for CAM. It is possible to run Cam on surface?
