True position callout with non datum axis basic dimensions (using OGP measurmind software)
I am trying to figure out how to setup this TP callout using an optical CMM (OGP). I would be able to do it if both basic dimensions were on datum axis but the basic dimensions for the TP callout is on Y and a straight line basic dimension.
I guess the question can pertain to using the software more than anything.
I have attached a small screen capture of the print which should show you what I mean.
RE: True position callout with non datum axis basic dimensions (using OGP measurmind software)
If not, then I think I'm completely out of my depth and hopefully someone else here can help you out.
That brings me to my next question, the design intent of this part is that the straight line dimension is what really drives the functionality of this part; because it's pivoting from the right side hole. As long as the straight line dimension is good/close, the part should function as intended. The issue is that radius nub feature is very far out in Y (which functionally does not affect the part) but is throwing off the TP callout (I am getting variances as much as .030" TP).
I am wondering if we can come up with a new dimension scheme that address the straight line dimension, is a little slack for the Y dimension, and still verifies the diameter of the nub feature.
Maybe put a +/- on the straight line dimension, and keep the +/- on the diameter callout.
Also, I believe you might need to use a basic angle in place of the .122 dimension if you chose to use this method.
Can you provide a screen grab that also shows datums A & C. I understand that you are considering a drawing revision to modify the way the position of the .099 dia feature is controlled. But when performing a dimensional inspection you must base your measurements from the datum reference frame defined on the drawing. In the sketch provided the .099 dia feature shows two basic dimensions (.122 & 3.958) relative to datum B, but there is still not enough information shown to determine the precise relationship between the feature and datum B.
Another consideration is that in your example datum B is defined as the primary datum in the positional tolerance for the .099 dia feature, which is a bit unusual for this type of situation. If you refer to the ASME Y14.5 bidirectional positional tolerance example provided by M4C7, you'll note that the primary datum listed (datum A) is the surface the hole feature axes are normal to.
Dave has a good point. Since B is Cylindrical, primary, and RFS, it already arrests 4 degrees of freedom. A single point as tertiary is all that is required to sufficiently constrain this part for the feature specified. No need for all the extras. Another point is that the nub does not appear to be a feature of size and thus should probably be located with profile.
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I would disagree on these points: If it is implied that surface A is the primary datum for B, then surface A should also be the primary datum for the cylindrical "nub" feature position tolerance.
Also since the positional tolerance for the nub cylinder is defined at MMC, there are implications with regards to its feature size.
Interesting discussion.
That's not a good assumption to make. If datum surface A is just hanging out in space while assembled, there needn't be any reference to it. As it is, reference to A adds absolutely nothing and really needs to be removed from the feature control frame.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
The question asked in the OP was related to how to interpret the positional tolerance shown for the .099 dia feature when setting up the part in their CMM. Design intent is never considered when inspecting a component. The positional location of the nub feature must be inspected based on its relation to the datum features listed in the tolerance block. While the screen grab did not include the part of the drawing where the definition of datums A & C were provided, as you pointed out the positional tolerance for the nub feature seems to give conflicting requirements by including A as a secondary datum.
The person performing the dimensional inspection of the part must comply with the requirements as shown on the drawing. If the drawing requirements are conflicting, incomplete or ambiguous, the inspector should request guidance from engineering. But the inspector should avoid making up their own interpretation of any unusual or unclear GD&T situations like the example provided. Engineering drawings should be looked at as a set of QA requirements that the finished component must conform to, rather than being a set of instructions for manufacturing to follow when producing the component. If the tolerance for a feature requires inspection based on certain datum surfaces under certain material conditions, then that's what the inspector must use to validate the feature. Design intent should not be considered by QA.
To be frank, using the machined hole cylinder surface at RFS as the primary datum while also using cast/forged datum target point features (A & C), makes inspecting the machined nub feature more difficult than it needs to be. While I appreciate the design intent of doing this, it also means that each part must first have this hole surface probed relative to a cast/forged surface A (which may not be accessible to the CMM probe) just to properly inspect the nub feature using the CMM. Since this part seems to be made from a forging or casting, it would be best to use the tolerancing approach typically used for these components. The machining and casting/forging drawings should use a common system of coordinated datum target points that the initial machining operations are based on. And after a fully constrained set of datum features are machined on the casting/forging, they will serve as the basis for all subsequent machined features. With these accurate machined datum features in place, an inspection fixture based on these surfaces can be used with the CMM to speed up the inspection process.
I'm not hugely familiar with using datum targets, but I did have a question about this statement. If datum target C is calling out a line, then I agree with what you've said above. However, if it is instead calling out a point (impossible to tell from the available view) would you not need to reference datum A to fully constrain the part?
Thanks.
Thanks for the lecture on how to inspect a part. I figured as long as you were making suggestions on how to alternatively set up the datum reference frame that I could do the same. Guess I was wrong.
M4C7,
A part does not necessarily have to be fully contrained to be sufficiently constrained. Think of a tube. If you specify the OD as a datum feature and then relate the ID to it, that's all you need. You don't have to arrest rotation around the datum axis nor do you have to arrest translation along the axis.
On the other hand, if datum A were primary, then you would have to use two other features in order to constrain it enough to make repeatable measurements.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
As this part was first drawn in the early 90's, i would assume the datum scheme was designed for measurement on an optical comparator where you would restrain the part with a fixture containing a gauge pin for datum B, with the nub feature orientating downwards towards the the floor, up against a simulated datum A plane (holds the part parallel with the comaprator). I would then think datum target C would be to hold the part rotationally about B? Datum C, as territory would only need the 1 point to fully restrain the part.
Currently, i place the part on the surface of the CMM on the opposite face to datum A. I then edge find an arbitrary intersection of the part to define my XY and start the automated program. The program uses a laser to define Datum A and align my XY plane to it. It then grabs points for Datum B and the nub feature respectively. Measuring this way, i cannot see why i would need the datum C, unless i hear back that i would need to use the touch probe to properly grab datum B and then would require me physically restraining the part to accommodate touch probe forces.
I think the goal should be to revise the drawing to describe useable parts and reject ones that won't work. What method is in place to determine how to make that determination and whether a particular tolerancing scheme will serve to adequately separate the two cases?
It would have allowed for a more meaningful discussion if you could have provided the entire drawing rather than just a snippet of it. It seems like all the participants have a pretty good understanding of GD&T practice, but since you were unable to provide the complete drawing there is quite a bit of debate on how to interpret your example.
In your last post you mentioned this is an injection molded (plastic?) part. Based on the tight tolerances shown for some of the features, I would assume this drawing describes finish machining operations performed on the molded part. If so, this brings up another important consideration when creating your datum references. With molded/cast/forged parts you must account for any draft or variation of the as-molded surfaces when setting up the part for the initial machining operations. Typically there is a system of datum target points (A1/A2/A3, B1/B2,C1) shown on the machining drawing that establish 3 orthogonal datum planes that the initial machining dimensions/tolerances are based on. Once there are sufficient machined features to establish an independent datum reference frame, the original system based on datum target points is no longer needed. Since with your machined component you mostly care about the relationship between machined features, you should base your arrangement of dimensions/tolerances to be inspected on machined datum features, as suggested by 3DDave.
You might also take a look at ASME Y14.8.
3DDave; There is no sorting as currently, there is not "good" and "bad" parts. They are all functionally working. Now functioning and functioning optimally are two different beasts and i hope to hone in on the ladder. This also needs to be done because we are preparing for a material change and I know the new parts will not pass the FAI unless the print undergoes some changes.
I also attached the entire drawing.
As-is, the drawing is missing too much information to repair. There needs to be a tolerance scheme devised for the entire assembly that this is part of and then tolerance analysis based on existing production capability to determine what might be done to correctly dimension and assign tolerances to a new drawing for this part, and probably most of the other parts.
Since the nubs aren't features of size, they aren't good candidates to establish a DRF, though limited surfaces of them might be used as datum targets.
To make one interpretation correction - A is the centerplane of the .170 thickness of the part;
I have to disagree on the parts not meeting the print cant work, I have physical evidence of that. that being said I have the opportunity to obviously open up some tolerances. Since this lever rotates about "b", as long as the 3.956 dimension is achieved, it's irrelevant where the nub lies in y with respect to the lever faces. At some point being out in y would cause an issue but on these parts currently it's not an issue. That is why i was asking for a new scheme on how to hold the straight line tolerance and diameter but be a little lax on the y dimension.
I am not going to make a new $35k mold if I can make a print update to match the tooling output because functionally, the parts off the tooling are perfectly acceptable.
While we're on this print, in regards to a lot of the middle view true position call outs ( on the slots and ovals), are they incorrect because there is no basic dimensions referencing them?
I appreciate all the good information, this is really helping me understand better.
When a datum feature symbol is attached to the size dimension of a width feature of size, the center plane of the width feature (to be precise, the center plane of the true geometric counterpart) becomes the datum plane. See attached Fig 4-13.
If you instead attached the datum feature symbol to the feature surface or an extension line, then the surface itself would be the datum feature. Again, please reference attached image.
https://www.youtube.com/watch?v=OJR3HQYsTVk
Season
The diameter symbols need to be deleted as indicated by the arrow, since it’s just a width not a circular feature. The position callout here means the symmetrical relationship between features of size, the distance between the center plane is an implied basic zero dimension, that why you can’t find out any basic dimension.
Season
Season
