Opening ST - Synchronous Part, "solids" greyed out
For some reason, when I open a synchronous part template like I always did, the program wants to start in sketch mode where solids, patterns, and some other panes are all greyed out. Any idea what setting may have changed to make this happen? I can't find anything under solid edge options that helps.
Thanks in advance.
Thanks in advance.
RE: Opening ST - Synchronous Part, "solids" greyed out
Can I convert a drawing begun in Synchronous into Traditional, or do I have to start and stay in one environment for a given drawing?
