precision unit with EC centrifugal fan
hi engineers
I have one A/C spilt precision unit (refrigerant type )for computer room
what's the suitable fan should be used in indoor unit?
cat loge that suppler show me its with EC centrifugal module-radipac
see attachments please
my question is this fan suitable with precision indoor unit ?
please advise
thanks
please advise
thanks
RE: precision unit with EC centrifugal fan
The sole fact that some components are offered by salesmen "from the shelf" instead of being recommended or urged by manufacturer technical support - is quite fishy for me.
As HVAC engineers we have broad range of knowledge, but such precision units require specialized expertise which must be offered by supplier, otherwise they wouldn't be needed at all and computer room can be cooled by ordinary comfort cooling - which is also allowed by some computer room setups, but has to be confirmed by computer equipment supplier.
This is simply not an issue of room cooling, but delivering proper amount of air at proper speed and temperature near local spots that require most of cooling - to avoid heavy overcooling of the whole room by general-purpose cooling.
So, you either send direct questions to manufacturer's technical support - or change supplier.
tomorrow this a tech. meeting with suppler ,I will high this points
