Display error in UG NX
I am using UG NX 7, in windows 7. Everything else is working just fine but in modelling and assembly, the parts are displayed in a weard way, even while taking dimensions in sketching mode, same thing happens.
I've attached the image, please help
RE: Display error in UG NX
No attached image!!!
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
We should have a "sticky post" about NX graphics...
NX is highly sensitive to the graphics adapter. *
1) You should use a certified graphics adapter. *
2) you should use a certified graphics driver. *
* NX might run fine on any graphics adapter but, if you see strange graphics you are on your own if the graphics card is not on the certified list.
Siemens has a list of certified graphics adapters and drivers. A certified adapter/driver is a Siemens tested and supported combination.
See https://support.industrysoftware.automation.siemen... down the bottom there is a tab named "certification" , click the "Hardware (Graphics card) certification"
* I know users who run NX on Nvidia Geforce and are happy with this, even if these cards are not certified.
* If you have problems using a certified combination, call GTAC.
* Only graphics adapters for CAD is certified, not gaming graphics adapters.
Tomas
