Mirror and Flip Extrusion
Hi I'm trying to add extruded text to a block but i need it to be on both sides. As of now, I've independently recreated the text on both sides but is there any way to mirror and then flip the text? I can only mirror but then the text is backwards on one side. Trying to see if there's a way to flip too so if the text changes it both sides will update automatically. Any help would be appreciated. Thanks.
RE: Mirror and Flip Extrusion
Another alternative is to create a UDF that accepts a parameter for the text and the two placement surfaces, and then some references to locate the text. At least this will cut down on the tedious nature of the activity.
mirror+flip=rotate
