Pressure dewpoint out of air dryer
Your assistance is appreciated
the usual specification for dryness of instrument air at dryer exit is a pressure dew point of - 40 F. Take the pressure at this location to be 100 psig.
Question is what variables would need to be adjusted:
first, to give this value - 40 F at 100 psig
second, which to give - 40 F at 115 psig
third, to give - 30 F at 100 psig
If you feel this thread is not within your purview can you please indicate which group might be more involved with this?
Thank you
RE: Pressure dewpoint out of air dryer
Look at a psychometric chart, it has water content vs. temperature and pressure for air. The bottom line is that a -40F (or C) dewpoint at 100 psig would have a larger mass of water vapor than the same stream at 115 psig.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. ùGalileo Galilei, Italian Physicist
