Linux: Draftsight vs ????
I have been using Draftsight for a few months and I like most things about the program. The esnap works well, toolbars for most of the common actions, command line keeps focus if you need to type location, and for many things it seems to use the fewest steps (compared to other CAD programs) to make a drawing. But I have some problems that prevent me from using Draftsight, random crashes, mouse lag, unable to print color (it worked before), and the config settings could be easier to navigate. I have tried other programs such as LibreCAD, ARES, ARCAD, and a few others, but so far the only one that seems to work well for me is BricsCAD. I would like to hear your opinion (good and bad) on CAD programs you have used in Linux before I spend a few dollars on one.
RE: Linux: Draftsight vs ????
... because the version that was working just fine for me has timed out, and the newest version is not available/supported on 32 bit Linux systems.
Mike Halloran
Pembroke Pines, FL, USA
Like its predecessors, it doesn't really fit well on my laptop's 1024x768 screen. It seems to assume the screen is much bigger. I think I found a setting that shrunk the display to the correct size in a previous version. I wish I had written that down, or remember where/if I did.
I'll put another copy on my desktop, which has a bigger screen. Draftsight used to work fairly well on the small screen.
Medusa managed to open a few AC14 .DWG files that I had. I think there's some 3D information in them; they didn't cause Medusa to crash, but there seems to be no way to rotate the display to visualize the perspective.
I honestly don't know if Medusa is displaying everything that was in the files, because it's been so long since I generated them.
Medusa4 Personal is billed as full 2D/partial 3D, but so far I haven't been able to find a 3D anything. Maybe I should read the manual...
Mike Halloran
I've used IntelliCAD products like BricsCAD and CADopia, but these products did not run that well under Ubuntu. I've migrated to Fedora since and have been using DraftSight on my Fedora Linux computers (desktop and laptop), and Windows machines at work, for about 3 years.
For the colour printing issue, I too had it printing to my Brother MFC-J6510DW colour 11"x17" printer and then it started only printing in black and white. The issue is not with DraftSight but with the printer driver. Here is the work around: print to pdf format first, then print the pdf format to same printer and colours are there; plus you have a "revision snapshot" of the drawing in pdf format, which may save your bacon if you need to present the drawing and your computer crashed or such.
The only thing is that, if the drawing is not a schematic, and scale matters, you have to make sure that the pdf printing paramaters to not stretch the drawing to "fit" the paper format.
For the mouse lag : never had this, I suspect you lack in RAM or CPU bandwidth. Possibly shutdown other applications while using DraftSight. Possibly time to upgrade your hardware or get another (used?) machine with more power.
For screen issue: many laptops, even in older models, have a video port for an external screen. Today it's possible to purchase a used screen of a decent size and resolution for little money.
I had two IntelliCAD licences that I have abandonned for Draftsight with no regrets.
The only thing that confuses me in DraftSight is the management of Paper space versus Model space, when you're trying to setup a printing view. Can't seem to find a toggle or state indicator; changing paper sizes is also not obvious for me. Anyone?
Hope this helps and maybe one of you can help me with my paper size management and space mode toggling / indication.
Cheers,
xian
(Christian)
Best Regards,
Christian Martel, P. Eng. PMP
I installed CentOS6, which is basically RHEL with no support. Fine.
Next problem: The least inappropriate Draftsight version available, 64 bits now, is for Fedora.
It downloads and seems to install without problems, shows up in the proper menu position, and ... does nothing. It will not start. It is properly associated with the DWG file type, and it won't launch that way either. There are no messages of any kind produced.
I gave up on Fedora long ago, because it's a bleeding edge kind of thing, gets updated very often, and the updates often break stuff. Not often like Microsoft updates blowing up, but often enough to be aggravating. I prefer CentOS, which evolves more slowly.
... but now, I'll have to reboot into that accursed Windows and use Draftsight there, in Bill's Bizzarro world. Yecch.
Dassault, are you listening? Please support CentOS.
Mike Halloran
Using YUM to install Draftsight in CentOS 6.6 appears to work, in the sense that no error messages result,
and doesn't work, in the sense that nothing appears to happen when you try to start Draftsight.
The installed Draftsight (draftsight-2015.3.0.3019-1.x86_64 ) won't start.
Trying to start it from the command line
$ /opt/dassault-systemes/DraftSight/Linux/DraftSight
reveals that Draftsight expects to find:
GLIBC_2.14
and
GLIBCXX_3.4.15
neither of which are present in CentOS6.
So far as I can tell, they are not present in CentOS7, either, but I haven't actually tried that.
Those libraries are present in Fedora21, and I think in 20 and 19, so the Fedora rpm provided by Dassault
should work on Fedora 19-ish and higher. ... but not, alas, CentOS6.
Containers are alleged to solve library problems, but containers are no longer supported in CentOS6,
and I have found no evidence of anyone having used containers or anything else to get
Draftsight to run on CentOS7.
I tried a live DVD of CentOS7, and hated the 'simplified' interface, and most everything else about it, so I'm not upgrading yet.
Can anyone report a successful install of Draftsight on Fedora, or Ubuntu, or OpenSuse, or .... ?
Mike Halloran
MeX Linux 64 bit Live version can be installed to a USB thumbdrive.
It is based on Linux Mint, which is based on Ubuntu.
http://mex.exton.net/
... and it occasionally boots. The same .iso boots better when installed to a DVD, but then you don't get persistence.
There seems to be some difficulty with the nouveau drivers for my nVidia card.
... and after squawking about some broken packages, and telling you how to get them fixed, the Ubuntu Draftsight .deb file will install on it, and it seems to work, and pretty fast.
So far, I haven't been able to get the persistence working, so I've had to reinstall Drafsight several times.
Also, it doesn't boot exactly the same way every time. The author includes some words about which thumbdrives work best.
You definitely want one with an activity light, which is not a given anymore, so you can tell when it's being written to, or at least have some idea that something is going on and the damn computer has not just gone off into the weeds.
Mike Halloran
http://mex.exton.net/mex-usb-persistent/
from CentOS6.7.
I tried using YUMI in Windows7Pro to install a bunch of other distributions.
http://www.pendrivelinux.com/yumi-multiboot-usb-cr...
it seems to do a super job of installing 32 bit distribution live versions,
and sets up a nice boot menu so you can select from several at boot time,
and add or remove them at will under Windows.
It doesn't do that well with 64 bit distributions.
Some of them seemed to work, but really came up as 32 bit versions.
Some of them wouldn't boot at all.
Mike Halloran
The newer, 'better' version of Linux from the same author, called ExTiX 15.3 with LXQt 0.9.0 and kernel 4.1.0-3-exton, boots much more reliably, and the persistence works, but it absolutely refuses to install the Draftsight .deb file.
I tried that 'distro' because it allegedly comes with nvidia drivers installed by default, but attempts to adjust the nvidia settings produce messages that the nvidia drivers are not installed at all. Also, I like MeX' interface much better, but 'exton' alleges that the nVidia drivers don't get along with Gnome, so Gnome was replaced with LXQt.
The one 64 bit distribution for which I initially had hope is FatDog64, derived from Puppy Linux, which has a long history of working perfectly from USB sticks and multisession CDs with persistence, but FatDog's authors elected to build their own package manager, so FatDog can't use a .deb file or an .rpm file.
Such is the blessing, and the curse, of Linux. If you don't like it, wait ten minutes, and some random hobbyist will have released yet another new and improved version, that you may or may not like better, and which may or may not do anything useful, or anything at all.
You might want to install MeX and Draftsight on a USB stick while you still can. You'll need at least a 16Gb stick; 8Gb clearly isn't big enough.
Mike Halloran
