Aluminum alloys for engine blocks and heads
Hi...i'm working on a proyect and i need to know the aluminum alloys that are usually used on the engine blocks and heads..any information on this issue would be appreciated...Thank you.
José Luis Walters.
RE: Aluminum alloys for engine blocks and heads
for sand cast components, alloys 356/A356 are used for blocks, and 319 for heads.
for die cast components, alloys like 380 and 390 are used.
