Sec VIII Div.2. Longitudinal Joint(Category A) can be type 3 weld???
Hi to everyone.
This is my first thread so please accept my errors.
I am eager to know if my vessel has longitudinal (Category A) joint of Type 3 according to Sec VIII Div.2 table 4.2.4, I can't design as per sec 2?????? or what i consider the weld joint efficiency as per table 7.2????
RE: Sec VIII Div.2. Longitudinal Joint(Category A) can be type 3 weld???
I would read it that, if you have a longitudinal weld (Type A) that conforms to Joint Type 3, that it cannot be designed under the Section VIII, Division II, Part 4 "Design by Rules" rules.
It might be possible to do a design under Section VIII, Division II, Part 5 "Design by Analysis" rules, but I don't know the Code well enough to say.
Hopefully someone more expert than I can answer you.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
I thought nobody gonna even look at it but you atlease gave me some hints..so happy as you are the first one who reply me in eng-tip for my first thread.Great
Further detail of my problem...My vessel jacket's longitudinal jont (Category A) can be weld only type3 because its two piece(vertically split). plus my jacker sealer ring is fixed both top and bottom so i CAN NOT weld the jacket before and than slip it on inner vessel. what are the possibilities in such case to calculate the jacket shell thickness(Weld effieiency) either in sec1 or sec2.
