elevated condensate return
Do you see an issue if i connect condensate return from tank coil to an elevated return line without pump. Steam source is 105 psi. Elevation difference between condensate trap and tie-in location is 20'. Check value will be installed after trap.
RE: elevated condensate return
As long as you have specified the trap for the proper back pressure (taking into account any flashing in the downstream piping) this is a fairly common practice.
