Assigning material property based on stresses
I am modeling a body in which based on max shear stress the elements will change their material property. Please suggest how can I do it?
Can it be done without using subroutines( by python scripts) if not which subroutine, I should follow.
Any help will be appreciated.
RE: Assigning material property based on stresses
I have a body of steel in which based on shear hydride will nucleate, so i have created orphan mesh and a code to assign hydride properties but this code should take the data from results in each increment as explicit algorithm.
Hi
The answer for your question is USDFLD subroutine.
Best,
Bartosz
