flow control orifice
Hi
Have anybody heard the term flow control orifice ?
which part of valve it refers to?
thanks in advance
masoud
thanks in advance
masoud
best regards
Masoud
RE: flow control orifice
Flow control orifice Might be used for certain control valves where the flow opening might be changed by removing a mechanical piece and replacing it by a different piece with other measurements for the opening. Different zizes of orifices (openings) can also be selected under fabrication for some regulation or control valves, to suit (together with suitable formed closing member (cone, clack etc)) a best possible regulation of a given flow spectre.
Flow control orifice can be found as the flow opening closed by the valves closing member, might also be part of a construction placed inside or outside the valve, for instance in a separate, throtteling disc outside and/or far from any valve.
I do not think that the term usually refers to a control valve component
Yes and no GH Hartmann, there is a lot of different trees in valve-world forest, but I admit some of the types might be out of the common way
