Measure parts edge
Measure parts edge
Hello everyone,
Is there a "quick" way of measuring complete edge of a complex part? (or any workaround)
I have unfolded sheet metal part and need to know outer edge length so i can determine how much time we need for machining...
Thanks.
Thanks.
RE: Measure parts edge
Switch to GSD, and on unfolded body, extract a surface using Tangent Continuity (to have only one surface), then use Measure Item (with perimeter set on).
I believe this can be also automated....
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
can you explain what u meant by "then use Measure Item(with perimeter set on)." ?
Fernando
thanks for the help,
i did what you wrote only problem is it counts in all pilot holes i have on the surface but still, i can work with this.
Thank you...
