support on bends
support on bends
support on bends
Dear friends,
I want to specify seven supports on 50D bend of a pipeline; but in CAESAR II, in bend section I can specify three supports in different angles. How can I specify more than 3 supports in different angles of a bend in the pipeline?
RE: support on bends
You just need to break the 50D into several smaller bend elements by identifying the tangent points in the offset geometry. I would recommend plotting it out first.
