steam mains air removing
Hi
At the end of steam mains which works periodic (8 hrs per day) thermostatic air vent is installed.
I wonder if there should be fitted check valve after thermostatic air vent to prevent air to come back when steam line is cold.
What do you think?
What do you think?
RE: steam mains air removing
Does the equipment that the steam line services have a vacuum rating?
http://www.tlv.com/global_pdf/tii/e-pamphlet-12-hp...
http://www2.spiraxsarco.com/us/pdfs/IM/im-4-105-us...
Thank you for your help.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. ùGalileo Galilei, Italian Physicist
YES! But in addition, use of thoroughly dry air is almost always a necessity for good pneumatic systems--particularly where freezing temperatures can be anticipated.
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
