square bracket text in parts list
I searched and did not find answer.
In my drawing template, I don't assign attribute to the PART NAME column in parts list. I type the part name text into this column. The problem is the list shows square brackets[] around the part name text, as you can see in attachment. How do I get rid of the bracket?
I use NX8.5.
Thanks.
RE: square bracket text in parts list
Right Click on your parts list. Go to cell style or style look for a switch that mentiones highlight manual text. Turn this switch off.
Thank you SDETERS. It works.
Hi SDETERS,
I couldn't find the highlight manual text. Could you please share the screed shot. I am using NX8.5
Ganesh
I GOT THE SOLUTION THANKS
