position tol of a slot
here is the drawing callout.
a slot of .335/.330 long and .215/.210 wide with full radius at the ends. basic dimensions to X and Y.
under the length, pos .010 M to A B C, under the width, also pos .010 M to A, B, C.
how to interpret it?
is the second pos too many?
how to include max material condition in this case?
thanks.
thanks.
RE: position tol of a slot
Two considerations for feature acceptance, assuming that A is perpendicular to the slot opening.
1) That the slot is within the size limits for the length and width
2) That the slot not encroach on a idealized feature that is the least width - position tolerance and least length - position tolerance that is centered on the true/basic location and is perpendicular to the primary datum.
The idealized feature in this case is .330-.010 = .320 long and .210-.010 = .200 wide.
If Y14.5M-1994 governs the print, the word BOUNDARY is missing below both feature control frames.
Tunalover
Looks like we have different versions of Y14.5M. Mine shows the note BOUNDARY applied under two position fcfs in fig. 5-47
Y14.5-1994, fig 5.47
Y14.5-2009, fig 7.34
