Scared of anything not linear static
Here's a general question to all you FEA hotshots who perform non-linear analysis, including plastic and crush simulation etc.
How do you validate your results, and feel confident about the correctness of your analysis?
I know that for linear static FEA, I can (4 out of 5 times) back up the analysis with some manual calc. and sleep well at night (if you don't count the crying baby...)
Any comments?
Any comments?
RE: Scared of anything not linear static
Test, Test, Test - even if it is a scale physical model or a another simplification of the real structure. Of course you can do simple bounding calculations on many components that act non-linerly, although the bounds may be quite wide. There is no simple single answer, execpt that the validation is too important to 'forget' about!
TERRY
Raj
How do I sleep at night? Well, if the first order non-linearities agree, then in a sensibly designed system the second order interactions won't be too far wrong, and the third order interactions should be negligible. Hoho.
Cheers
Greg Locock
