Existing Concrete Slab on Grade with Cork Board - Overlay with new Concrete?
I'm working with an Architect to turn a grade school gym into a fire station to house (4) trucks and (1) ambulance. The existing slab is 4" (probably un-reinforced) with 1/4" cork board overlay and then a gym floor on top. The glue holding the cork board down has asbestos in it and needs full abatement if it is removed...this is approximately $35,000. They want to add 4-6" of concrete height to the existing floor for drainage reasons.
Question, would it be feasible to come in with a 4" slab reinforced with WWF and pour it directly on top of the cork board? If not, why not? 1/4" cork board doesn't seam like much, and settlement would likely be negligible?
RE: Existing Concrete Slab on Grade with Cork Board - Overlay with new Concrete?
I think you may need that additional thickness for strength reasons as well. Wheel loads from a full size firetruck are no joke. I think you need more info on the existing sub-base and the particulars of the wheel loads before you can make an informed decision on the over-pour. Without knowing the quality of the sub-base I would be making some very conservative assumptions on the slab design...4" slab with WWF wouldn't be cutting it. I don't think pouring on the cork board is much of an issue.
I was thinking 4" on top as that would give me around 8" total. The sub-grade is questionable though as I have no information on it. The building was built in 1961!!!
Emergency vehicles have axles that are rated higher than commercial vehicles. I have a single rear axle fire truck in my station that the rear axle is rated at 30,000#. Its not loaded quite that heavy but pretty close. Large ladder trucks can have dual rear axles rated at nearly 60,000#. Then there is the question will they support the ladder truck on the outriggers inside the station. These loads will far exceed the wheel loads.
I am assuming you are suggesting using WWF for the control of the crack widths and not strength? Personally, I wouldn't waste the time or money on rolled WWF. Either go with a plain slab with a close control joint spacing or heavier WWF sheets or even rebar along with a longer joint spacing.
There are a lot of 6" and 7" plain concrete roads in this country that hold up. If you soils are decent, you might get away with a 6" slab.
I was also thinking that the existing slab would act like a very well compacted sub-grade. I will keep looking into it.
Here is an idea (IF YOU CAN MAKE IT WORK......AND CAN PROVE IT).......
Epoxy vertical dowels thru the cork into the bottom slab at say 12" or 18" oc each way and let dowels project up into upper slab. If you can prove that you can create two 4" slabs that have equivalent bending or shear strength of 7" or 8" slab by testing or analysis........then you are good to go! Good Luck!
I have done 8 to 10" fire station slabs using PCASE. You have to know enough on the subgrade, subbase and the number of times the slab is expected to be loaded by the trucks. I would only try to make the existing slab work as composite (and not as a separate member sharing load) with a new pour by roughening the existing slab, epoxy doweling, and epoxying on top of the existing slab before the new pour. That's if I was to count on bending strength of the existing slab and not assume it is a subbase. 4" isn't a lot to dowel into though.
If that much would be spent getting rid of the cork, I would inquire into cost to remove the slab along with it and start new.
The idea of treating the slab as a subbase may work but I have never done this before.
I would want some type of geotech input on the soil below, at least allowable bearing and modulus, before going forward with any design.
My thinking with the 4" slab with the cork board now is that I will treat it as a base and not as part of the structural concrete. It seams to be a really fuzzy area and I haven't looked at doing something like this before and thought it would be worth exploring the possibility.
I think doweling into the existing slab is not a very good option. I'm not sure I really see any issues with over-laying an 8 or 6" slab (if it will work) and assuming the existing slab is base material. Will the cork board squish? I'm sure it will, but I'm not sure it will squish enough to notice. It's an interesting to talk about the possibility though!
tear it out and design a proper slab.
