Unit of Measure Conversion Problem
Hey guys,
I don't know why I'm having such a hard time cancelling out units here, but here's my predicament. We send out a couple materials to have some MVTR (Moisture Vapor Transmission Rate) testing done to see the permeability of each film. The units we got back were in g/Pa*s*m^2. I have a data sheet for another material that we're looking to switch to and that one has units in g/m^2*D. I'm trying to cancel the units out, but not having luck! I think it's been too long since I've done this stuff.
Do any of you have any insight on this?
Thanks so much!
Thanks so much!
RE: Unit of Measure Conversion Problem
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
The units are not equivalent. according to wikipedia, the first is permeance, which WVTR/pressure difference, which, presumably, is a way of describing the WVTR with some indication of how much pressure is required to achieve a certain level of WVTR
TTFN
Thanks so much for the input, though!
