dough divider problem
Our dough divider machinery is not working good.
It can not divide dough into similar desired weight.
I do not know much about mechanical design, but I have noticed that an indicator is not in its place like the other one.
Please let me know what does that indicator do?
Is it possible that this little deviation reduce the power of the arm to press the dough?
I uploaded a photo of the machinery.
Please let me know if you need more information.
Best,
Best,
RE: dough divider problem
Ted
A dough divider works by squeezing the dough flat into a pan and then a cutter will cut the flattened dough into equal sized squares or wedges. If the pieces are varying in weight then the dough is not completely filling the pan due to not being squeezed far enough. There may be a squeeze adjustment, or you may not be adding enough dough. There is no way to tell from your picture. Call the machine manufacturer, or read the operation manual.
