Fresh air make up unit
Hi , we are upgrading the ambient and design temperature from 45 Deg & 25 Deg to 55 Deg & 22 Deg. So now the owner doesn't want to change the unit. Instead of changing the units he wants to add a FMAU. Here is the details
Existing Unit details:
Air flow - 9000 CMH
Cooling kW - 140. 0 Kw
Air On : 34.45°C DB, 29.88°C WB
Air Off: 13°C DB, 12.5°C WB
Please guide me, how to select the unit and I did rough calculation and the result is about 265.0 Kw.
Air flow - 9000 CMH
RE: Fresh air make up unit
