pipe network tissue heat transfer
i need to know the formula to calculate the amount of heat transferred in a minute from a tissue, with a certain volume and kept at constant temperature, to the fluid, contained in a network of pipes, flowing with a certain flow/minute and at a certain inflow temperature, supposing that temperature of the tissue and the temperature of the pipe fluid equilibrate (get the same) at the outflow of the fluid from the tissue
RE: pipe network tissue heat transfer
Da an energy baææance.
On the fluid side you know it all:
Tin, Tout=skin temperature, flow rate: Q=(Tin-Tout)*Q*Cp (liq)
How accurate do you need your answer?
How fast do you want your answer?
How much do you want to pay for your answer?
Given a choice between quality, speed, and price; you can always get two of the three.
