Turboexpanders Liquid Vapor
Could you indicate how to manually calculate expander hp for vapor service and liquid service? I think several of you would have done these calculations, but if there is one or more which was verified by actual use, that would be a big help, too
thank you
RE: Turboexpanders Liquid Vapor
See attached link:
http://article.sapub.org/10.5923.j.ijee.20120204.0...
Essentially it is the reverse of calculating gas compression horsepower
