PUMP SYSTEM TDH 1100 m, Q= 1020 m3/Hr
Dear
I have a new project for sea water of 1020 m3/hr and TDH, 1100 m, I thought of the design with two pump station (550 m each station)
and three pump in each station, but There are two alternative types of pumps to use, a) horizontal multi stage and b) Turbine vertical multi stage.
I would like to have your views on this type of pump considering costs and maintainability and operability.
I will be grateful if you have a similar application that can comment me
regards
Victor
regards
Victor
RE: PUMP SYSTEM TDH 1100 m, Q= 1020 m3/Hr
It appears that the multi-stage vertical turbine pumps do not quite achieve your hydraulic coverage (Sulzer, Goulds, Ruhrpumpen, Flowserve)
I did find a between bearing BB3 multi-stage horizontal axial split case pump from Flowserve:
http://www.flowserve.com/Products/Pumps/Between-Be...
Not sure the Sulzer or Ruhrpumpen can provide your coverage. It appears a similar model is available from Clyde Union
As far as the merits of vertical vs axial split, I will leave that to others. The vertical pumps always have the potential for shaft deflection and vibration whereas the between bearing pumps minimize any such problem.
Let us know what you choose,
you must get smarter than the software you're using.
Suggest you contact the major pump companies with full design data, a little more detailed than what you have supplied to us - unless of course this is a "I wish" project and there isn't any design data available.
Could you please some more detail why should not think at vertical turbine,
Thank you
Victor
Horizontal multistage splitcase is probably your best option here. Even if you go with one pump you can easily meet the Conditions of Service. You are looking at probably minimum 36 weeks for one of these pumps; maybe as much as a year. I would look at one of the Big Boys for this pump: Sulzer, Goulds, Flowserve.
Probably should think about materials of construction before you get much deeper in to this. Your material selection will be critical to the reliability and life of the pump. The link below is to an excellent paper on seawater materials.
http://www.google.com/url?sa=t&rct=j&q=&am...
Do you have any specific manufacturers in mind?
I know nothing about the Japanese suppliers
Been away from the front end of the pump industry for a long time now - Mitsubishi comes to mind, maybe Hitachi - there were others but all a bit hazy on who's who now.
ITT Industrial process, Goulds Pumps
What Goulds models did you find? I could not find any that provided enough hydraulic coverage for the OP conditions
www.framo.com is their website.
Is it a pipe line installation where the head is mainly friction or a high pressure inject. If it is a long pipe line installation, where the head is mainly friction, 2 stations installation will required lower pressure piping and cost of the pipe line.
Vertical multistage pumps should be avoided unless there is NPSH problem or the intake design is suction lift arrangement.
