Automatic Attribute annotations - title block values
Hi All,
I'm setting up drawing templates with title blocks etc...
We use the master model method (i.e. separate drawing and part files.) I want to get to the stage where; with a model file open, a user can click file>new then select the right drawing template and the fields in the title block will be auto-populated with attributes from the PART file (which was open).
So far I've got the stage where I can get the part filename though to the drawing (i.e. using <W@$SH_MASTER_PART_NAME> ) but I can't get any other information (from file>properties>attributes in the part file) to filter through.
I know this question has been asked before and i have looked at this thread http://www.eng-tips.com/viewthread.cfm?qid=228567 but i seem to be having a problem with it, i followed the process but when i open a new modelling file and then open a new drawing it does not seem to want to link, what am i doing wrong, do i need to save this to the database or what? Anybody that could give me a 'fool proof' guide would greatly appreciated!
James
RE: Automatic Attribute annotations - title block values
To link to model part attributes, you create an attribute in your template part DB_DWG_TEMPLATE_ATTRIBUTENAME, where ATTRIBUTENAME is the name of the attribute in the model part.
I can't recall if you can embed those in a titleblock, but I can't see why it isn't possible.
Video #3 at https://vimeo.com/album/3065578 is one I created in the drafting template series about attributes and linking them.
Anthony Galante
Senior Support Engineer
NX3 to NX9 with almost every MR (18versions) plus the NX10 Beta
