Weld Metal Heat Treating for 4140
I am trying to weld 4140 to 4140 and then heat treat to achieve 120 ksi yield of the base metal as well as the weld metal. I'm not a welding engineer, therefore I am looking for a pre-qualified procedure or method which lays out how to do this. I have been working with AWS D1.1 although in para 3.14 it disallows heat treatment to achieve a base metal strength of greater than 50ksi. Can anyone point me in a direction where I could find the correct procedure or let me know if what I am doing is even possible or sound.
Secondly the weld area is the least stressed area of the entire part. The weld undergoes reversing cycles between tension and compression. I only need a PJP groove weld to meet the allowable stress of 0.3 times the weld wire strength as defined by AWS D1.1. Should I use the heat treated strength of the weld wire or the as deposited strength of the weld wire? Is it advisable to use a PJP groove weld in tension? The total cycles for the life of the weldment is only 100, so I'm not terribly concerned about cycle life.
RE: Weld Metal Heat Treating for 4140
The kinds of questions and the way you are asking them suggests you need to retain a welding engineer from the realosphere.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
