part list for sub assembly in top level assembly drawing
Hi All,
1. I am creating drawing sheets in top level assembly and I called my sub assembly and created views. when I want to create part list for sub assembly I am getting part list of top level assembly since my drawing sheet in top level assembly. Is there any way to crate sub assembly part list in top level assembly drawing sheet.
2. In drawing sheet If I want to annotate top level assembly (parent) name what is the annotation expression? for example top assembly : Top1.prt and sub assemblies Sub1.prt and sub2.prt. I want top assembly part name in sub assembly drawing sheet
Thanks in advance
Thanks in advance
RE: part list for sub assembly in top level assembly drawing
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Could you please help me, what annotation represents top assembly part name in sub assembly drawing.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
This is by design and will never be changed!
This is what allows you to add, as a component, any part file, even if it's been saved on disk as 'read-only', to your assembly without having to first get 'write access' to those files. If you think about it awhile, you'll understand why this is critical. Take for example a simple bolt which is used in hundreds of Assemblies. Should the Bolt file be required to carry with it a record of every Assembly that it's being referenced in? If it did that file would continue to increase in size as it was used over and over again and it would have to remain open to being written to by anyone, not something that you ever want to do with a 'standard part' (which BTW is why family members, created from master family template parts, are created 'read-only' BY NX ITSELF).
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am using native NX 8.5. instead of manually, is there any other way to select file for part name
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
