4330 Modified (3.40 Ni) Charpy Results Failing - Need Heat Treat Advice
Greetings,
We are using a 4330 modified;
C - 0.32
Mn - .60
Si - .26
Ni - 3.40
Cr - 1.20
Mo - .48
V - .118
We need transverse -40f impacts @ 34J average no lower than 27J
We cannot meet these requirements after many different heat treatments.
Does any one have experience with this grade mod and heat treating?
All I could find was an investigation by US Army that concluded;
Austenize @ 1500f, i hour, oil quench and double temper at 400f (2 hr. AC + 2 HR AC)! However their Ni was half ours (1.80)
Thank you, pulling our hair out!
C - 0.32
Mn - .60
Si - .26
Ni - 3.40
Cr - 1.20
Mo - .48
V - .118
RE: 4330 Modified (3.40 Ni) Charpy Results Failing - Need Heat Treat Advice
Sulfur - .002
Cu - .16
58" x 103" - 4330MOD Ingot(s) Note the high Ni
Anything else that could help?
Longitudinal - 160 ksi (1103 mpa)
Transverse - 160 ksi (1103 mpa)
Yield 0.2% Offset Min;
Long. - 145 ksi (1000 mpa)
Trans. - 145 ksi (1000 mpa)
Elongation in 2" Min;
Long. - 14%
Trans. - 10%
Reduction in Area, Min;
Long. - 38%
Trans. - 25%
AISI 4330V mod/1.6562, Firmodur 6562. Assuming forging and heat treatment are within stated parameters, your chemical ranges are slightly out of range with what is stated for the alloy mentioned. Your elevated V content would concern me along with the current carbon content regarding achieving target impact values.
Can you explain your concern regarding V? It should help prevent grain growth during hot forging, which should have a positive effect. I know that there are complex effects with regards to temperatures used during thermomechanical processing and other elements like N, Al, Nb, and Ti.
For one or two lots, normalize at 1775F, then Q&T as normal.
If it is a process stream, I would look at the cooling from forging. With that high V and Cr contents, and the Ni, you will get a lot of M23C6 carbides at the forging grain boundaries with slow cooling. It takes a very high austenitizing to break these carbides up, so either cool quickly from forging temp to below 1200F or so, or include a high temperature normalize. The object is to not let these complex carbides form at the grain boundaries on cooling from forging, or if they do, dissolve them (>1750F) again prior to hardening.
If you can control the austenitizing, you may find austenitizing at 1775F, cooling to 1500F then oil quench will work, if you can keep the time at the time >1750F well controlled (<30 minutes) and can soak at 1500F prior to quenching.
You may also investigate secondary hardening to maintain strength. I would think a tempering temperature of around 1100F could still maintain the 145K yield and the higher temper would help the impacts. With < 0.005 Sulfur, the impacts in the longitudinal and transverse directions should be similar, particular with Calcium treatment, and 34J (25 Ft-Lb) shouldn't be that difficult with this alloy at this strength level.
rp
Thank you again for your time it is much appreciated.
Higher Ni is added obviously for toughness. As pointed out, if the cooling from forging was too slow (especially at center portion), and forging finish temperature was too high, you would get coarse grains and coarse, or even networked carbides, both of which are bad for impact property.
considerably increasing temeprature to break up the carbides sounds a valuable suggestion. Slight increasing temperature, say 1550-1600F, maybe another method worth trying to maintain a cerain percetage of austenitic phase to increase the tougness without much sacrifice in strength.
We then had a "McQuaid-Ehn" Test performed = ASTM 6.0 !
More questions than answers now..........
Fine grain melting with .02% to .04%. Then Normalize & Quench and temper.
Assuming that you are stuck with existing wrought material, see redpicker.
The coarse grain is no doubt due to the forging conditions (time and temperature in furnace and final forging temp and degree of hot work) and while the grain can be refined by normalizing prior to Q&T, it will never be refined to finer than 6 with heat treatment. If you have more reforging billets of this material, control the forging conditions and heat treat as above. Tempering at 900F to 1000F should meet you tensile properties.
Take a look at the the Isothermal diagrams at the following link, Page 32.
http://www.nickelinstitute.org/~/Media/Files/Techn...
While you are not dealing with isothermal transformation, the diagram indicates that above 900F, the austenite transformation is very sluggish. Transformation can take hours to complete (heck, even start!) at these temperatures.
If you can cool quickly to below 1200F or so, you run little risk of hard spots or cracking issues (since little transformation will have taken place). One way to accomplish this is with fan cooling and monitoring surface temperature. If you are dealing with large sections, you can cool until the surface is black (check with a non-contact pyrometer) and allow to air cool past that.
Once below 1200F, the assumption is that the cooling rate to room temperature will be faster than the austenite decomposition rate, so that the carbides will form in the 600F-800F range, which are likely to be well dispersed and more of the Fe3C type of carbide. In general, the faster the carbides form on austenite decomposition the faster they will dissolve on austenitization.
rp
When you got astm 2 grain size, your may focus more on decreasing grain. What is your final size of bar after forging? if there were limited reduction at forging, the center of ingot could get no deformation, and no much of recrystallination occurred, leading to big grains. course grain structure can be refined by re-designing forging parameters, and/or by thermal cycling between room temperature and normalization.
Maui
They are taken from the surface
We do both longitudinal & transverse
Ingot is 58" x 103"
Forging is saw cut to ~22 x 27 it is from there that we take the samples
Mn - Our Avg. 0.57 - others at (1)~0.265 & (2)0.80!
Si - Our Avg. 0.25 - others (1)0.075 & (2) 0.26
cr - Our Avg. 1.16 - others (1) 1.475 & (2) 1.14
Mo - Our Avg. 0.47 - others (1) 0.57 & (2) 0.48
As we are almost identical to second "other" (2) except Mn & First "other" (1) we are off on all, other direction in Mn this is confusing me.
Questions; (a) we are in the middle more or less on Mn, both "others" are making the mechanicals - why?
We are trying to determine how to move forward with new steel requisitioning, what is our best chemical composition to achieve above mechanicals..........
Are the "others" you are comparing too using the same section size?
I am a little confused on your section size. You mention a 50" x 103" ingot, a 10" x 10" block, then saw cutting the forging to 22 x 27. 22 x 27 inches? How do you saw cut 10" x 10" to 22" x 27"? It just doesn't make any sense. You say the test specimens are taken from the surface? The centerline of the test specimens cannot be on the surface, it has to be at least 1/2 the thickness of the test specimen below the surface. I just don't understand what you are trying to do.
"Others" are using same ingot as us. The ingot is large but we are getting the reduction as we are doing other grades of same size ingot 58" x 103"
The finished block is saw cut from the drawn out forging. The blocks are ~43"l , 23"w, 26"h - sorry for confusion on that
Test specimens are taken out of a "Quarter T" configuration. Cut 91/2" off block, flip that section, cut 11" in, cut and turn 8", take coupons
This should be 35-40 HRC which should use a tempering temperature of 1100-1125F. What heat treat cycle are you using? A thickness of 23" is very large to to be trying to quench, are you sure your quench is effective?
Best result heat treat cycle;
Normalize - 1775° - 16 hrs. @ temperature
Brine quench to below 800°
Quench – 1600° - 16 hrs @ temperature
Brine Quench to below 250° (brine 45°)
1st temper 1100° 18 hrs. @ temperature
Put in water to below 100°
2nd temper 1080° 22 hours @ temperature
My question pertains more to ordering new steel and the different chemistry "others" are using particularly as it pertains to Mn........
What is the surface condition of the parts like? As-forged, including forging scale? Have you taken an as-quenched hardness? Is it low (below 401 BHN)?
If so, you might want to mill the surfaces to clean metal. That will improve the effectiveness of the quench. Be sure to break the corners to 0.75-1.0" x 45 deg (you could put a 0.75" Radius on them, but that is a bit fancy) to reducing cracking tendency. Yea, with 0.32 C you shouldn't have a cracking problem, but when you're dealing with 3-1/2 tons of steel, a quench crack can ruin your day.
The good result as quenched hardness's have been 451-460.
Of the three chemistries, do you see one that stands out as better for this situation?
I will add information as I get it
Some of the parts have been milled prior to quench, did not have influence on mechanicals (same result as hot top or spout)
1. Use one of the standard specifications as a guide. If this will be conventional air melt + vacuum degas, not a consumable electrode process (VAR, ESR, etc.), then reference SAE AMS 6427 or ASTM A646.
2. Here is the composition specified in ASTM A646 for 4330 Mod.: C = 0.28-0.33, Mn = 0.75-1.00, Si = 0.20-0.35, S = 0.012 max, P = 0.015 max, Cr = 0.70-0.95, Mo = 0.35-0.50, V = 0.05-0.10, Ni = 1.65-2.00, Cu = 0.35 max.
3. Specify that the prior austenite grain size must be fine. Typical is for ASTM #5 or finer, but you may want to specify #6 or finer based on your data/test results.
4. Review the specs for information related to steel processing, inspection requirements, etc. Are you specifying requirements for macroetching of ingot or subsequent worked products (billet, bar, etc.)? What about NDT for surface or sub-surface defects?
