Problem with hydraulic circuit
Can someone help me with my simulation.
I have made a hydraulic circuit and I don't know what i'm doing wrong.
It's just a simple circuit, I want to combine 2 cilinders in a closed hydraulic loop. So we don't need a pump/motor and hydraulic reservoir. I want to add a mechanical force on 1 cilinder (pull or push to the cilinder rod) and then I want to see what the result is in movement with the other cilinder.
This is my circuit (in attachment), I hope someone can find my mistake!
