API PIPE TO ASME VESSEL
Friends
Can I use pipe API (5L, X60, X65, etc) as a body in a small pressure vessel designed accord. ASME rules?
RE: API PIPE TO ASME VESSEL
SecII PartA.
Be careful and consult with your AIA.
The API material may be used provided that the requirements of the API material meet or exceed the applicable ASME specification. Code interpretation VIII-78-38 gives some insight on this matter. Although this interpretation addresses the use of ASTM material, the general concept is still applicable.
The requirements of UG-10 allow the use of materials not specified by ASME code so long as they meet the requirements as specified in UG-10 and the applicable material spec. Just be sure to discuss with the AI and there should be no problem.
Also, see UCS-27 "Shells made from pipe". Don't forget that the wall thickness for pipe products must be reduced by 0.875 to account for undertolerance (UG-16d). This seems to forgotten often.
Be sure to check metlsmith's suggestion about the size of the vessel. Although it may be small, there are still maximum and minimum pressure limits when applying Sec VII Div 1.
please go to the following:
http://www.usstubular.com/products/erwslp.htm
Grade B (ASTM A53, A523, API 5L PSL1) API 5L PSL2
Minimum Yield Strength: 35,000 psi 35,000 psi
Maximum Yield Strength: None 65,000 psi
Minimum Tensile Strength: 60,000 psi 60,000 psi
Maximum Tensile Strength: None 110,000 psi
Notes: This grade may be used for standard pipe, line pipe, or conduit pipe as specified in the various ASTM and API
specifications
this is a check same as ASME SA 53B
May be OK for SECT 8 DIV. 1
