Single Profile for revolved body using section curve?
I would like to get a cross section of a turned or revolved body, but only get one section curve. Right now I am using the section curve command with NX 8 and for a revolved body the plane intersects the body in two spots. I only need one profile of the body not two. I did extract bodies and trimmed them, but the problem is that I have extra features and bodies that can get messy. I would like a simpler solution. I typically wouldn't care about this, but it's the people I work with.
RE: Single Profile for revolved body using section curve?
If so, try changing the view boundary to manual rectangle and window around the section of interest.
www.nxjournaling.com
Tomas
