Bolted Joints - Recommended Norms ?
What aerospace norms()or references do people use/recommend for detailed stressing of bolted joints ?
Which are the most used in aerospace circles?
Thank you
Mr. F.
Thank you
Mr. F.
RE: Bolted Joints - Recommended Norms ?
Some specific to aerospace not included in the FAQ above:
DOT/FAA/AR-MMPDS-01
MIL-HDBK-60
MIL-DTL-1222J
NASA NSTS 08307
NASA MSFC-HDBK-2071
ECSS-E-HB-32-23
There are "best practices" that should be employed when installing any larger cluster-pattern of fasteners in primary or even lighter secondary structure. these practices ensure even settling of parts together resulting in best/optimum fastener load distributions and minimal structural distortion. IF structure is assembled without employing these "best practices" then really odd assembly problems will surface, or in-service premature failure are highly likely.
These best practices are especially critical when assemblying structure with various type fasteners [solid/blind rivets, bolts/nuts, lock-bolts and/or Hi-Loks, blind-bolts, etc] and fay surface sealant.
I haven't got time to note these specific practices, right now.
Regards, Wil Taylor
Trust Me! I'm an engineer!
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant û "Orion"
