Remember Constraints for Position Overridden Sub-Assembly
I have a sub assembly which has been used in a main assembly as a component, and it has a positional override. How can i make its own assembly constraints to the subsequent adding in the same main assembly.
for an example, assume a cylinder with position override to be mated multiple times in an mechanism.
Manikanda
RE: Remember Constraints for Position Overridden Sub-Assembly
Try this option: Menu > Assemblies > Component Position > Rememberred Constraints.
Thanks Selvaraj,
Am trying the same and i could able to apply this for a sub-assembly which doesn't have the position override.but am failing if the component have any position override.
Manikanda
