API 620 Footnote 16
API 620 Footnote 16
API 620 Footnote 16
In section 5 of API 620 there are several references to Footnote 16
(e.g. "NOTE: See Footnote 16 for information applicable to Equation (10)" on page 5-21).
The only Footnote 16 I can find is in section 4 on page 4-10:
"If better grades of bolts are used, higher bolt stress values are not recommended with full-faced gaskets."
This doesn't make any sense. Does anyone have any idea what the real footnote might say?
RE: API 620 Footnote 16
If you are looking at the 12th Edition, 1st Addendum, the note is properly Footnote 18 and can be found on page 5-19. This note was formerly Footnote 16 and the references to it were not updated. I will make sure that it gets changed.
