Export all notes to a text file or to the spreadsheet in NX9 Drafting
Application Drafting:
Is the an easy way to export all notes to a text file or to the spreadsheet in NX9 ?
I need this function to send the .txt or .xlsx for translation
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Export all notes to a text file or to the spreadsheet in NX9 Drafting
Try the following journal:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UI
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUISession As UI = UI.GetUI
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim myDocs As String
        myDocs = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments)
        Dim outputFile As String = IO.Path.Combine(myDocs, workPart.Leaf & "_notes.txt")
        If IO.File.Exists(outputFile) Then
            Try
                IO.File.Delete(outputFile)
            Catch ex As Exception
                lw.WriteLine("error deleting file: " & outputFile)
                Return
            End Try
        End If
        'pass False to overwrite existing file, True to append existing file
        'if file does not exist, a new file will be created and the True/False value will be ignored
        Using myWriter As New IO.StreamWriter(outputFile, True)
            For Each tempNote As Annotations.Note In workPart.Notes
                Dim noteLines() As String
                noteLines = tempNote.GetText
                For Each noteLine As String In noteLines
                    myWriter.WriteLine(noteLine)
                Next
                'leave blank line between notes
                myWriter.WriteLine("")
            Next
        End Using
        'lw.WriteLine("notes for NX part file: " & workPart.Leaf & " have been exported to: " & outputFile)
        Dim response As Integer
        Dim messages(3) As String
        messages(0) = "notes for NX part file: " & workPart.Leaf
        messages(1) = "Have been exported to: " & outputFile
        messages(2) = ""
        messages(3) = "Open file now?"
        response = theUISession.NXMessageBox.Show("Notes export complete", NXOpen.NXMessageBox.DialogType.Question, messages)
        '1 = Yes
        '2 = No
        If response = 1 Then
            System.Diagnostics.Process.Start(outputFile)
        End If
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
www.nxjournaling.com
Hi Cowski
Thank you and I wish you an happy new year
Didier Psaltopoulos
