Flash Relief of subcooled liquid at valve inlet
Hi everybody,
I've some queries regarding relief valve calculations for subcooled liquid at inlet. My process involves water in subcooled state (170bar, 320deg.C). The relevant equation for omega-s parameter as per API 520 is 9*((rholiq_at inlet/rho9)-1). My query
1. what is the origin/ justification for '(' used above & also the above equation in general
2. I've some confusion in estimating rho9. API says it is the density evaluated at 90% of Psat corresponding to inlet temperature. This means about 102bar for my case. IT also says about isentropic/ isenthalpic flash. Should I take enthalpy at inlet (i.e. subcooled conditions) & carry out the flash to 102bar? in that case i'll get superheated vapor condition (i understand that rho9 is the liquid density). Please help.
RE: Flash Relief of subcooled liquid at valve inlet
see this discussion at eng-tips forum
"http://www.eng-tips.com/viewthread.cfm?qid=332483"
you may compare results of HEM vs HNE ,
by the way Omega parameter gives a simplified solution of HEM method,
better to use the rigorous method (see Prode or similar tools).
