hardness of the welded joints for ASTM A 537 Cl1
Dear sirs
hi, our project is to supply a missing prefabricated carbon steel shell plates , the grade of the material is ASTM 537 Cl1 with 19 mm thickness , all these prefabricated steel plates are inculding manholes of 24 , 36 inch falnges , of course these flanges are connected to the shell plate and its reinforcing plate through nozzels.
Due to the huge volume of welding and because of the plate thickness (19 mm) , the plates should be PWHT according to the code API 650.
we did the PWHT as following
heating speed : 50-75 C/hr
soaking temperature: 650 C
soaking time: 1 hr
cooling speed: 45-50 C
cooling in the air out of furnace: 350C
we got a deformation in the shape of the strucure , this distortion has concentrated in the area of reinforcing plates and manhole openings.
our questions are:
1- can we get the geometery of the deformed shape by heating by tourch (heating up to 650 C and for less than 15 sec)
2- does it effect the structure of the steel itself
3- does the hardness of the welding joints effected by this process
4- what is the maximum acceptable value for hardness for ASTM 537 Cl1 within the welding joints
waiting for your kind answer please
soaking time: 1 hr
our questions are:
RE: hardness of the welded joints for ASTM A 537 Cl1
