Concrete Column Unsupported Length
I am double checking what the standard practice is for determining the unsupported length of a concrete column on the first storey of a building (without getting in to anything like horizontal soil springs, etc) .
I have a situation where my footing was lowered about 9' below the slab on grade to accommodate some piping. Is the unsupported length from:
A) the underside of the slab to the top of the footing
or
B) the underside of Level 2 slab to the slab-on-grade. The slab-on-grade is 5" thick with mesh and the soil is properly compacted.
or
RE: Concrete Column Unsupported Length
DaveAtkins
If that is the case than both would be the unbraced length but worst case I think would be B. But you can only use the slab as lateral support if it is tied into the column with reinforcing.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
And I would use 3' because that seems to be a common assumption where fixity is assumed for the lateral restraint of piles.
I would rely on the soil to provide the lateral restraint required but wouldn't try to create a rotational fixity of the column.
