Blend versus Non-blend
I have been reading through ASTM D2000 and corresponding standards, however I cannot find specific detail on how composition is controlled. I have field failures of a part specified to be polychloroprene (neoprene) per ASTM D2000 M2BC etc. I have been supplied with third party FTIR revealing the material to be a neoprene/SBR blend. The parts were subjected other testing specified such as hardness, tensile, heat aging, ozone, low temerature, etc and were found to meet all other parameters tested in accordance with the ASTM D2000 callout on the drawing.
For all practical purposes I think the parts meet the drawing, however I have been double guessing if a blend is sufficient for the specifications.
My question is; even if the parts meet all testing specified per ASTM is a blend considered polychloroprene? Are the specifics to what percentage of the material must be neoprene?
Thank you!
Thank you!
RE: Blend versus Non-blend
There are many masterbatches with SBR as the matrix, but if I would see more than 5phr SBR, I would assume it was intentionally added and not originating from masterbatches.
