Chord wall plastification for RHS .
I have a shear plate with axial force welded to the face of RHS column, when i checked the chord wall plastification using design guide 24 the wall failed, i am considering using reinforcement plate welded to the face of the RHS, but my concern is how will i insure that the plate will work together with the wall of the RHS, let us assume that there as an axial tension force in the shear plate the plate will act as if there a prying action effect right??, will using a spot weld for the reinforcement plate be enough to assume that the plate work together with the wall of the RHS.
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
RE: Chord wall plastification for RHS .
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
Tony A. Gaskins Jr.
