Slide Rail/Slide Bearing Type
Hello there,
I have been looking far and wide for this type of bearing/rail system that I have seen before but can't figure out what it is called to search it on the web and order it. Basically it is a curved square tube with a smaller curved square tube inside of it which slides in and out. I would assume it has ball bearings. I need this slide rail to open the lid on a cabinet up and back. I have attached a sketch of what it should look like. Any help is much appreciated.
RE: Slide Rail/Slide Bearing Type
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
I attached a PDF file which shows how it should look, or at least the general idea of it. I will attach again.
Maybe a problem with your viewer? It opened ok for me.
Basically a rectangular section bar sliding inside a similar-shaped tube, but with the whole thing curved into a quadrant shape.
