Type of Slide Rail/Bearing
Hello there,
I have been looking far and wide for this type of bearing/rail system that I have seen before but can't figure out what it is called to search it on the web and order it. Basically it is a curved square tube with a smaller curved square tube inside of it which slides in and out. I would assume it has ball bearings. I need this slide rail to open the lid on a cabinet up and back. I have attached a sketch of what it should look like. Any help is much appreciated.
RE: Type of Slide Rail/Bearing
I can't say I've seen anything similar In Real Life.
Bishop-Wisecarver used to advertise v-rails supported by v-rollers, and suggested that the rails could be bent 'the hard way' to make curved guides, but I don't think they're stocked in that form, and they're much bulkier than what you've sketched.
Mike Halloran
Pembroke Pines, FL, USA
I've never seen any commercial product like that. Frankly it seems like an expensive type of mechanism for producing a simple rotary motion. As MikeHalloran suggested a system of v-rollers attached to a bracket that guide a semi-circular v-track would be much more efficient.
