Integral pump question
I would like to integrate a pump within a gearbox to lift oil from the sump level to above the bearings. Forgive me as pump selection/design is absolutely not in my background.
I would prefer a non-wearing design (e.g. centrifugal) that will last a long time. Efficiency and pressure are less important than reliability and ability to continue to move fluid over a wide range of fluid viscosities (e.g. 50,000 cP to 10cP). I wish to attach the pump impeller on either the 1800rpm input shaft or 350rpm intermediate shaft. I expect to build a scroll around the pump impeller to pipe the pressure side upward to a trough where gravity will take over. Flow would need to be 1gpm minimum and head would be around 2ft. Specific speed is therefore very low.
I've done some homework but it seems all of the guidance seems to be based on optimal efficiency for a given specific speed, and there are no clear winners. As I mentioned already, optimal efficiency is less important than a robust, maintenance free design.
What kind of pump might be capable of doing this?
Where might I be able to buy the pump impeller alone, for integration into my machine?
David
David
RE: Integral pump question
Johnny Pellin
