Elevator machine rooms
IBC states elevator machine rooms are required to be rated the same as the hoistway. If the elevator machine room is sprinkled do you still have to rate the room?
RE: Elevator machine rooms
Yes, because it's part of the shaft. And I'm using the 2012 IBC.
