Adjoining different coordinate systems
Hi corous
you have replied to one post in the following sentences(If you've defined the faces as sets then remove the common edge from one of the sets by using the ctrl button when selecting. )but,I could not get what do u mean for set for edge and also in which part I have set these sets,since I have had the same problem in ABAQUS?
best regards.
Mehran
best regards.
Mehran
RE: Adjoining different coordinate systems
