Export operation
Export operation
Export operation
I have a problem in exporting a geometry I have created.
More precisely, I want to export my model in such a way that it appears as made of only one solid instead of all the boolean/extrusion operations.
Can someone help me with this issue?
Best regards.
RE: Export operation
File > export > parasolid if it's going to be later imported to NX
> STEP if it's for another system
www.jcb.com
NX 8.5 with TC 8.3
Edit -> Feature -> Remove parameters.
This will delete all the feature you've been using to create your solid.
At the end you'll get an unparametrized solid.
Be carrefull, this can't be undone.
"My english is bad ? That's why i'am french."
Thank you both very much for your quick reply!
